How to prepare for Jira Align in Jira
Objective
Do you want to learn more about our recommendations for preparing the Jira instance for Jira Align (JA)? This document outlines some key steps to help you prepare for Jira Align for your organization.
Be sure to let your Advisory Services representative know if you're interested in learning more about Jira Align. They can kick off a conversation with the Jira Align team.
Jira configuration key takeaways
There is a lot to consider when preparing for a Jira Align integration, and there are a lot of resources available to you. This table aims to highlight key takeaways for critical Jira configurations and provide you with detailed articles that go in-depth on the reasoning behind each recommendation or best practice.
Jira Align allows you to selectively synchronize based on issue type or project. If you want to synchronize a board that contains a subset of issues from one or more projects, please note that all issues from those project(s) will be synchronized to Jira Align. Regardless of whether they are on the board or not, all of those issues are subject to applicable takeaways below.
- The first table below dives into specific checks that are called out @ Jet By Jira Align/ JET checks and their implications for those teams planning to onboard to Jira Align. Note that these are also detailed in the links we’ve provided, but this page attempts to consolidate this information into an easy-to-consume format.
- The second table covers additional considerations for Jira Administrators that are not covered by the Jet tool but are important to the Jira and Jira Align integration and scaling practices in Jira.
- While we do our best to call out specific checks and considerations, impacts, and actions to resolve any issues, there is a wealth of additional information indexed @ Jira Align and Jira Integration Best Practices and FAQ Table of Contents. Some relevant articles are linked in the tables below, but this is another great reference to assist you with your Jira and Jira Align integration.
Check in Jira | Why you need it | Impacts | Action to fix | Reference article |
Custom fields Mark custom fields as optional, not required. | Custom field configuration can affect your ability to integrate with Jira Align. If you only sync from Jira to Jira Align and you leave any fields as required, they will not be synced. If bi-directionally syncing between Jira Align and Jira, your issue will fail to sync if none of the required field information is provided. | Jet By Jira Align (Check #5) | ||
Epics and fix versions All Epics should have an assigned fix version. | Epics should have fix versions to dictate what release the epics will be shipped on; releases are tied to a project in Jira. | Not having this data hygiene won’t break the Jira Align connector, but it will prevent the real-time release progress visibility in Jira Align. | ||
Issues Stories should be associated with parent epics. | Not having this data hygiene won’t break the Jira Align connector, but it prevents overall visibility of the real-time progress. | |||
Sprints A single sprint should only be tied to one sprint board | Since one sprint board represents one team, if you have a sprint across multiple boards, it can be difficult to measure team-level progress. | |||
Sprints Sprints on a sprint board should not have overlapping dates, and the sprint should not be shared across multiple teams. | Sprints represent a planning and execution time slot for a single team—only one sprint should be active at a time. | |||
Stories and story points Stories should have estimated story points. | Not having this data hygiene won’t break the Jira Align connector, but it prevents overall visibility of the real-time progress and reporting. | |||
Teams and boards There should only be one project assigned to a Jira board. |
Additional consideration | Why you need it | Impacts | Action to fix | Reference article |
“Team” custom field and “Component” system field This applies if you have multiple teams on a Jira project and you are using a custom Team field to separate issues across different boards. | Team in Jira Align is specific to JA and doesn’t sync directly as a part of the connector. | |||
“Priority” system field | Too many priorities/priority schemes can cause complexity in your Jira ↔︎ Jira Align mapping configurations. | |||
Issue deletion | Disable the “Delete Issue” permission for all Jira projects, leverage the “Resolution” field, or leverage Cancelled/Duplicate statuses. | |||
Custom issue hierarchy apps | Jira Align does not integrate or account for app configuration. Any custom hierarchy established through an app will need to be re-configured and built as part of your initial Jira Align integration for each Program of Portfolio. Examples of such apps include: | Any issue above the Jira Epic within Jira does not properly sync to Jira Align. | ||
Issues in sprints (Jira) and features in program increments (Jira Align) | Carrying over issues across sprints in Jira or Features over program increments in Jira Align will adversely impact your reporting within Jira Align. | |||
Workflow |
Was this content helpful?
Connect, share, or get additional help
Atlassian Community
